RE: beginner's guide
Vodka Man does the plane you bought look like this or more like a glider. Perttime is right about the formosa rip off not being a good first plane, but if you are carefull and have good reflexes you should be OK, this plane is very forgiving for a low wing with ailerons, it also floats very well and has a very low stall speed, just make sure your CG is right before you try to fly it, don't assume because it is a RTF the CG is right
