Diamond Dust replacement
a Outlaw with floats... heard it all now! pics?
Ok, so you've got a Outlaw and a Magnum.
So two choices, First recover and put a drop of cyno on the Dust, or build a quickie 500 type plane.
I've got a Outlaw and Dust right now, and a Magnum soon. when that comes im not sure what slot the Dust will fill, the only thing it beats them both on is fast low level ground effect flying and that dosnt happen often enough. I actully think my dust would be better if i took out the MVVS and fitted a West 36 and pipe, then put the airframe on a diet and give it bigger elevons and maybe rudders.
ummm tho i do have a GRRT that needs testing out, right, im off up the shed with a hack saw so i can fit the carb and i'll see you later.
