RE: experince on Dynafite Butterfly needed.
Thank you Dr1Driver. I am going to use a .15 to power the plane. I also have a .25 that I might put in later but I need to get the thing in the air b4 i start making engine changes.
No ailerons and nose wheel will not be added b/c your right. I just need to stick to the plans to get my feet wet again. Building will not be a problem for me b/c I am carpenter/contractor so I build things all the time.
Again thanks for the input.
