TP-FSM Synth Module HK version!
Hi Guys
I have the above module purchased in HK (hong kong) on a trip.
After many months of thinking it just does not work I have eventually discovered that it only works on a limited (HK ) part of the 35MHz band, ie channels 75-82.
Whilst that is not the end of the world, it has occured to me that there must be an internal tweek that would restore the full range of channels.
I have removed the back and there are a number of pots with adjustment available.................. can any one chime in with a fix?
phil.
