Patriot XL setup questions
Hello,
I am getting close of finishing my patriot XL. I will be using a Magnum 91 xls and I am going to use an Hitec Supreme receiver with two Y connectors as well as retracts (B.D). I have a few questions regarding the setup:
1) Since the servo wires from the ailerons and the flaps are quite long, are you using any kind of shielding on the wires?
2) Are you running the receiver antenna inside the fuselage without any problems?
3) Is the C.G indicated in the instruction manual the right one?
4) Where are the parts to build the instrument panel? I cannot seem to find them in the kit.
Thank you for your inputs,
Le fou
