ORIGINAL: dougtx
I have a question regarding the TS-52 and spinners.
I know I know it’s not a Tru-Turn, (even if it were a Tru-Turn I think the issue would be the same) but I purchased a 4” Dave Brown Vortech Spinner.
The TS-52 (6 bolt hub) has the center shaft threaded for a 10-32 bolt, which is all fine and dandy, however, due to the length of the spinner, it looks like I will need a 10-32 bolt that is approximately 4” long in order to reach, and properly thread into, the prop shaft.
Is this correct, or am I suppose to use some sort of adaptor?
I'm running the same setup with no problems, I had them drill and cut it for me also.
