RE: getting close
1 of 2 things.
1. you need to raise the idle using the idle screw since when you use the brake it closes the carb, you need to turn the idle screw clockwise until the idle stays the same when you hit the brake
2. your cluctch spring is broken, will it start and run without moving? if not the cluch spring may be broken
i think its number 1 though
