ORIGINAL: irenaslavo
Caad5, I'm preparing car almost like yours, I took your picture as reference for my installation, I have problem with servos for hydraulic breaks, I install them exactly like your but when I made test both are working well but with opposite direction i.e the front break work the rear released, the front break work the rear break released , I'm using Y cable to connect both break servos , would you please tell me how you manage to let both working
IrenaSlavo i used a 3 channel radio/receiver and plugged the throttle/rear brake servo into one channel and the front brake servo into another channel. Then I used channel mixing to set it up with a 60% front and 40% rear brake bias. I also set it up so when i throttle/accelerate, the front brake servo does not move because it does not have to go back like the throttle/rear brake one does. I did not use a Y cable.
