Carbonfiber control links?
I'm using the Cental Hobbies ones with the titanium inserts on a 29% AW Edge. They work great. I also used black CA to hold them in - my personal pull tests showed it worked better than the JB weld that was recommended. I also slipped an aluminum ring over each end to keep them from splitting if there was a side load. I'd sure use them again and probably will on my 35% Carden Edge when I get it (kit anyway) next month. Good luck.
Hall
