AM and FM use different crystals. PCM and PPM both use FM so they both use FM crystals. Then on the reciever side you need to make sure you get a single conversion or dual conversion crystal depending on the receiver type.
Here's some reading for you:
http://www.torreypinesgulls.org/radios.htm
