RE: Building a 7'6" Crackerbox
Hi JS440,
Great!!! You can maybe give me some ideas of what to look for in a jetski set-up.
The room I have where the engine compartment is, is about 19" x 31". I can modify the bulkheads to add bigger if needed. Does a jetski from a kawi engine have room for my boat. I don't know what would be the smallest engine available in a stand up jetski. Could I be able to adapt a shaft collet and a shaft onto the engine's gears? Or do I need to install the water jet pump? If you could give me some ideas of what model and size that would be the ideal set-up for my boat, I can start looking around in a jetski junkyard of some sort. Any help would be appreciated.
Thank you.
