RE: ASM P-61 kit Build
Ron:
I used 30 minute epoxy..seems to be sticking pretty good...the top of the nacelle is no problem to glass..the bottom is something else...dropped the class cloth in and then position it in place with a wooden dowel,then when it is right,add a few drops of thin CA to keep it in place ..use short stripes 1-1/2" ...I used a magnetic mirror to make sure the glass stripes were in place..can get one at an auto store..BTW, have you looked at your wheels for the main gear? One of mine is round and the other is flat bottom....have tried to contact Hobby People, but no luck.. Right now, they are down at the LHS...Just in case yours are the same way,wanta trade?....Nice to have both that are the same..........Right now, am working on the elevator servo..my servo lead will be coming out on the right side of the stab....I see no problem there...Am using a HS-225 mg servo..fits good....take care and good luck
