RE: Prop size for brushless setup
Thanks ....
The specs I gave are all I have. Its a Chinese Ebay special so documentation apart from the electrical specs are a bit scarce and I was probably lucky to get what I have. No mention of prop size or if I need to run a gearbox.
The Formosa is a conventional layout - looks a bit like how pattern ships used to about 10 years ago only smaller. Something I would call a .10 to .20 size if it were i/c. Maybe I'll start with a 9x6 on direct drive and see how many amps it pulls.
Ideally, should this motor be running at 9.2A at full throttle?
