RE: Redcat Racing Tornado Thread
another question. I let someone use while I was at work. I get home and the car wouldn't start. So I called Redcat to set all adjustments back to original(they were changed). Still wouldn't run, I pulled out the Idle screw found it was damaged and burred. Replaced with a HPI one. I got the car where it will start(hard to do) but will not stay running, when I apply the brake it stalls. Would it be a carb problem now and is ther a HPI carb I can use? I can't get it to adjust correctly and there is alot of fuel/oil that pours out of the muffler when I angle the car. Please help, I wanted to go run it today.
