RE: Mixing flaps & elevator with Futaba T6EXAPS HELP!
It should be very easy to match up your computer and non computer radios, especially since the 6exa does not have a sub trim function so you should be getting to neutral elevator with the linkage. If the trims of both radios are centered when you do that, then you should come up correct regardless of which transmitter you use.
