RE: WACO YMF
Well we had another white weekend here in Omaha, at least it's not in minus double digits! I was able to spend most of the weekend in the basment (work shop) getting the servo mounts in, used some old servos (non-high torque) to set things up. I have the throttle linkage installed, rudder and elevators temporaraly mounted with linkages set up. Even the tail wheel works! Need to make the aileron linkages and mount the aileron control horns. By Golly think I am finally to the "fine sand" and start covering point.
NAH, I'm sure there is something else I forgot to do!
