RE: Q-Tee Build Thread
I wanted rounded wing tips so I took the wing tip block and layed it down but not quite flat to give a little tip diheadral (sp?). I just thought that might look a litte better.... I also used a spruce leading edge because I hate having a little branch or stiff weed denting or cutting my leading edge.
I think I will mount my landing gear all on the outside so that it can be repaired easier. I don't see how you can work on the landing gear very easily with it all up inside the fuse.
