RE: Q-Tee Build Thread
Howdie gents just thought I"d throw in my two cents worth. I like to bend my own gear.I use the two wire method. then mount them with nylon bolts.The bolts will sher just befor the mounting blocks tears loos from the fuse. The point that you attechethe brace will determine the dapening. the closer to the fuse, the softer the gear.
