Stick travel
The stick position/servo stops the same - about halfway each direction. I think I will start on a new memory and reprogram. I don't have any mixers applied. It is just a simple setup.
I think if I just resart from scratch I will figure it out.
Nother ?
The 7,9,12 receivers. Do they all have the same high resolution. Is it just the 12 that is compressed? The reason I ask is they advertise the 12 as high resolution on all channels and don't say diddly about the 7 and 9. I know the Tx has to be set to the proper parameter and that makes sense since you say the 12 uses a different algorythm. I just want to make sure if I get a 9 instead of 12 for a JOKER heli I don't give up any resolution.
Thx for input, I will post when I figure out *** I have done.
