RCU Forums - View Single Post - Redcat Racing Tornado Thread
Old 03-05-2007, 09:02 PM
  #160
evlfkr
evlfkr's Avatar
Default RE: Redcat Racing Tornado Thread
If its the stock plug, there only good for a couple of runs. Use an A3 plug. Did you mess with any of the settings on the engine? Do not touch the low end needle (the one in the center of the throttle arm on the carb it should be flush) If it needs to be broken in turn the high end needle clockwise gently until its resist, then turn it out 2 1/2 turns. Make sure the head bolts are tight and the carb and o-ring are compressed down onto the throttle body. (don't force it) Use a hot glow starter and it should start with a couple of pulls. Let me know?!
