Old 03-05-2007, 09:30 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Q-Tee Build Thread
A Q-TEE with no fuel tank behind the firewall should balance OK, but if you add 2 ozs of weight behind the firewall [fuel+tank], you will run into what DT is facing. His solution to the problem makes the most sense, plus it is good that he caught the problem at this stage VS later on. I eventually ran mine with a TD on the nose and a TD strapped to a power pod above the wing, and that model had the coolest sound to it, like a siren.
combatpigg is offline
