RE: Team OMP Presents the Boxxer ARF!
Radio Gear Install:
1: Begin by installing the tail servos. You will need two 12 to18 inch extensions. The length depends on the stock lead length of the servo. Install the extension on each servo by carefully removing the plastic connector housing. Plug each individual connector from the servo into the extension (matching colors carefully), and secure with small heat shrink tubing. This method is smaller, lighter, and more secure than simply plugging the plastic connectors together.
2: Install the top servo first by simply drilling the holes for the servo screws and slide in the servo. Next, install the bottom servo and pull both servo wires to the channel and push them in place in the channel in the bottom of the fuse. Cover over this channel with the supplied matching covering. (Clear tape used for photo.) A one inch wide strip approximately 24” long does a good job. Cut a small 1/8” x 5/16” hole in the bottom of the wing sheeting on the left wing immediately by the fuse and slide the wires in. Seal this hole and the ends of the servo extension wire tunnels with clear silicone.
