RCU Forums - View Single Post - Team OMP Presents the Boxxer ARF!
Thread
03-06-2007, 09:23 AM
14
TailTwister
My Feedback: (
1
RE: Team OMP Presents the Boxxer ARF!
3: Mount the throttle servo to the right side fuselage on two ΒΌ inch ply/balsa triangle servo mounts. Determine the proper location based on the engine you choose and remove a small amount of covering to make a good wood to wood contact point. After gluing the mounts, you should fuel proof them with thin CA (allowed to soak in a bit) or epoxy. After the fuel proofing glue has cured, install the servo on the mount with rubber grommets (supplied with radio gear) to protect it from vibration. Cut a small hole in the lower wing sheeting and thread the servo wire through. Do not yet seal this hole, as you may use the same hole, to run aileron extensions, if you have chosen to use the top wing aileron servo option.
4: The main radio switch can be mounted anywhere, but the ideal place is on the left side, near the radio hatch. You can also mount the receiver wrapped in foam under this hatch
Reply
Like
TailTwister
View Public Profile
Send a private message to TailTwister
Find More Posts by TailTwister
View iTrader Profile
