RE: Nitro models pusher Bobcat?
Wayne22,
Nice job, I really like what you did. Has anyone looked at mounting their engine inverted? If I do this I will eliminate having to buy a new header for my YS .60FR if I could even find one. If I do invert the engine I will have to make sure that there is enough air movement over the engine so it doesn't overheat.
One more thing, when I test fit the wings the through hole for the wing tube is not centered. I have one wing with a 1/4" gap and the leading edge and the other wing with a 1/4" gap at the trailing edge. Has anyone else had this problem?
