RE: Help needed with battery, Rx & ESC wires
Also I forgot- that esc is rated for 8 amps so make sure not to push it to hard. I believe the EZ Star comes with a speed 400 motor, and you should be fine, but if you decide to use 8 cell, 9 cell or lipo batteries you may exceed the 8 amps depending on prop.
