RE: SuperTigre mid-range problems?
i posted awhile ago that i was having a problem getting the 2300 to richen out at high end and ed i have been using tigers since the early 60ths. this was a problem that i have never had before everyone kept telling me to check the pressure tap that it was plugged this was a brand new set up and the first time the engine was run after going almost nuts over this problem i sent the engine back to the factory, come to find out the piston ring was in two pieces they replaced the sleeve and the ring so things do happen at the factory not often but enough to cause problems since i have got the engine back it runs like a tiger should I run it on 5% no more the idle is good the mid range is perfect i took my time and did a break in that you have to do with st engines
70 oz of fuel before i even started to adj the idle and mid range this engine is in a 1/4 yak 54 at 19 lbs flys it just like i want it to
clockshop
