RCU Forums - View Single Post - New 53cc engine now available
Thread
03-15-2007, 01:50 PM
29
rctom
RE: New 53cc engine now available
Here are a couple more photos. One shows the arms on the carb. The shafts are parallel with the cylinder bore so the arms are easy to connect to with a servo. The fuel inlet is also rotated so it's easy to hook up the fuel line, usuallyit is pointed straight at the throttle shaft.
The second photo shows what you get with the engine when you buy it fromWild Hare;
Stainless steel prop bolts (I have all the bolts changed to stainless, standard chinese bolts are of lesser quality), prop washer, exhaust gasket, spark plug, ignition, spark plug wrench, gasket set, muffler and the engine itself.
Reply
Like
rctom
View Public Profile
Send a private message to rctom
Visit rctom's homepage!
Find More Posts by rctom
View iTrader Profile
