Sounds awesome.. Got any pics of the fusion setup for the wing connection.. It doesn't sound like it would be that difficult to pull off.. Also, where are the videos
Sachin
ORIGINAL: AFSalmon
The first batch will be all color schemes like the pictures. We might do all white in the next run though if folks want that. As Wessco says the top wing is removable. The bottom wings are two piece as manufactured and glued onto the sides of the fuse with carbon fiber rods running through the fuse as spars. It is intended to be permanent just like the kit is. However it would not be too hard to modify the arf slightly to have the bottom wings removable. You could use a set of wing bolts simlar to how the Fusions are constructed. Just a thought....
