RE: Yellow F-15 ARF Assembly Thread
Hi Shaun,
Thanks for the CG info. I set it at 7.5".
There's nothing unusual in there. I did use a Power Box, Duralite Li Ion (RX)/Li Mag (ECU) and added the scale cockpit. I used some heavy-duty wiring when I built the servo leads; it’s the same stuff I use in my 35% aerobatic planes. Maybe that added to the weight. I am not too worried about it. I'm sure it's going to fly fine. Others must get close to that weight or over it with some of the scale functions, lights, etc. I see added.
I am not sure if I asked or not but do you have some tips for mounting the wing pylons, tanks and missiles?
Thanks for the help. It’s almost done!
Bill B.
