RCU Forums - View Single Post - Top Flite Cessna 182 build
Old 03-20-2007, 12:14 PM
  #35
teookie
teookie's Avatar
Default RE: Top Flite Cessna 182 build
Andy,
Yessirry Oregonians! The questions is are you a beaver or a duck? This is my first time building with ceiling tiles and it seems to be working very well. I was concerned that it would not hold the pins well due the surface texture, but it has been working so far. I'm -satisfied- for now with the flatness, but it is not 100% perfect. I think a piece of glass or granite would be the only truly flat surface, but then you cant use pins!
The fuel tank access is something I'm going to look into since I've had a tank leak before - not fun. Since I've decided to not use a cockpit kit, I do have more room to work with.
Later!
