RE: Little Toni with OS91
I always had my best runs on my os with a 13x8 apc pattern prop. I also changed out my needle with one from a os61. the 91 needle does not give you the fine tuning adjustment like the 61 needle does. That engine is easy to burn up if run to lean.
