RE: Dual receivers
I know this is an old thread but can somebody explain the theory behind two receivers causing reduced range.
Is the range reduced more with crystaled or synthasized receivers?
Does the receivers locally transmit theit IF(intermidiate or mixing frequency?)
How does synth receivers work without crystals?
If the recievers only receive and do not transmit anything, I can not see how two receivers can cause reduced range. People have said that the two anteannas interfer with each other, but if a receiver does not transmit anything.
So that is the difference between an extra antenna and a metal pull-pull cable as far as reduced range is concerned?
