futaba 9chp
You have picked the best combo for helis as far as I am concerned. You will find the 9C very easy to use. I went through mine and set it up step by step. It only took an hour or so and is easy to do. follow the book. You will get a good set that way. Set the pitch curves like your heli book describes and tweek them as you need to. If you go through it this way the first time, you will know the radio well when you are done. It is a very easy radio to set up so you wont have problems. Sorry I can't give you the exact numbers. I have different helis, but you won't have a problem with it.
