RE: ASM C-130
I HAVE FLOWN b-17 and b-25 all with my throttles just by y them in one with out any promblems. i put everything all in where they said and only added 5 oz lead in nose. I have a buddy of mine building one too ,he has painted his green and using gms 32 also. The engines worked out fine inverted after a lot of trail with glow plugs. the plugs that come with engines are junk. they would not hardly run engine at all! Be sure to use a little larger washer on bolts going in wing that holdsengine naclles on a blue loctite, they will work loose and dig into wood. thanks randy
