RE: Glow plugs
Nitro:
Jett has a 10 oz bubbbleless tank that works well and gives you enough fuel to fly a while, about 7-8 minutes with a 60LX. I need a few minutes to calm down and enjoy the flight, so is a good all-around tank. If by chance you have been using the Merlin plugs, I recently got a bad batch. They would only stay in for one start and run, then die. Was replacing a plug every run On Jett 35, 50 and 60, plus a Webra 55 every run. All had no problem when replaced with a OS 3-5 or 8, the only plugs I had left. Was first problem I have had with the Merlin plugs, one in the 35 was probably in there for a season of racing. (If it ant broke, don't fix it!!) ENJOY
