RCU Forums - View Single Post - Nitromodels PREDATOR RQ-1B
Thread
05-11-2007, 08:33 AM
14
papajeff
RE: Nitromodels PREDATOR RQ-1B
To install the wing servos and run the extensions, it's best to have all the parts gathered together. I have had much success using the MPI servo extensions and Y- adaptors and suggest that you use "new" ones rather than some "old" ones that just happen to laying around......know what I mean????? Measure the length of the lead on the servo and then determine what length extensions will be needed. You will find the pre-attached string taped inside the wing, when the servo opening is exposed. Attach the string to the servo connector and "carefully" pull the string from the wing root opening. Now, secure the servos in the openings. I did use the 9G mini servos from Nitro Models and since the wings are somewhat on
the thin side, the servos just might seem to set up a smidge (a very technical term) high which is just fine.
Reply
Like
papajeff
View Public Profile
Send a private message to papajeff
Find More Posts by papajeff
View iTrader Profile
