RE: Flair 1/4 Scale PT17/Stearman Build
redcesar, thank you for that input. So I would imagine that with the ST 710 at 70cc, I may want to follow what you did. Can you describe some of the issues you went thru to get you to where you are today? Like "at first the wing set at 3.5 deg handeled this or that way" That may go a long way to help understand the charcteristics of this plane with a larger engine.
Thanks!
