Rc Nitro Car Engine In Planes Is This True??????
To effectively use a car engine in a plane you would have to run a minimum 20,000 RPM. Any less than that and the the engine would be way over loaded and not nearly to the max power which is usually at 22k-27k RPM on a pipe.
