RE: Nitro Planes Falcon 120
A guy that came to our field once had a Bobcat, looks good, I don't know about the covering, some issues like weird servo mounting, exhaust and it took awhile to assemble at the field. It was FX61 powered and flew at about the same speed as my SX32 powered Kadet Seniorita, the muffler can be a issue (pointing backwards some tuning issues may allso be carb intake reverse airflow), if you want to actually go fast a real engine will be necessary, availible pusher props may be a issue allso. Looks good and price is reasonable but it depends on what you expect and if you put some serious power in it with some modifications it may or may not hold together. Maybe a Byron reverser tuned pipe could be fitted to get some extra RPMs and rear intake engine but some mods will be needed.
