RE: PITCH AND THROTTLE CURVES
Yes you can, you will use -9 and 9 or maybe even as low as -8 and 8. All depends on your motor. You will probably also want to add some bearings to the collective assy if you haven't already. Only the 37 with 550's will pull 10 and 10, 32's can't.
Jeff
