RE: Cermark Update F-18/F-16 propjets
when I check my gear for leaks I put 100lbs of pressure in the system with the gear up leave overnight or 2... no leaks put the gear down
overnight or two. no leaks GO FLY.. you should check your system after a couple of flights just in case something came loose..
then every so often.
