Marc and Kirk have resolved the issue!
Just for information, Marc Thomson and I have resolved the differences of opinion and have reached a compromise. Here is the e-mail message I got from Marc: "Since your offer, I called Horizon for some advise on servos . Failure
modes, things to look for, 4721 info specifically. I also did tests on all
the servos under load and they all pulled well. The only issue I have is
with one servo. It has more slop than the others and doesn't centre as
well. Probably gears. Would you be willing to spring for a set of gears and
a set of servo arm screws (3 were missing) and we'll call an end to this
mess. I'll post that we have a resolution if you do as well."
Marc
Marc requested that I send him $10.00 for new gears in the servo above, and I complied.
As for the some of the posts above, it would be helpful if folks did not jump to conclusions so fast. I was called everything from a liar to a cheat, and a rip-off artist. Those of you that know me, know that this is not even a little bit true. When I post, I do not use an alias, but my name. I also have my e-mail, my hometown, etc. As I stated above, check my Karma rating, and see what others say about me. Several of the above statements were hurtful, and should not have been said.
Kirk Andrews
