Thread: servo bounce
Old 06-08-2007, 03:46 PM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: servo bounce
Most probably a bad connection (a high impedance due to corrosion or cheap connector material) in the Y or in the extensions if you used any. Eliminate all the connections you can, use adequate size wire if extensions are required and use good connectors. To see if this is the problem, plug the servos directly into the receiver less any extensions and see if they work okay then; if so connectors are your problem.
Rodney is offline
