RE: the twilight zone ?
Hello all , I just got back from the field and the guy wasn't there. I am not sure whether the radio is ppm or pcm but regardless this type of interference should not happen with either. Keep in mind the right aileron or left depending on how you look at the plane moves to it's futher end point and holds there until the hand waving over the TX is removed. This isn't just a little bit of flutter.
DJ
