Old 06-09-2007, 08:04 PM
badger5964
badger5964's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Robart hinges
I used them on my Bridi Killer Bee. One must make sure there is enough stock to allow for strength. You do not need to have the entire hinge buried however. I used the drill point jig. Alignment was perfect. It is time consumiong as you must glue one side let it cure then add the other. If you do not want a large gap you'll need to recess the hinge into the control surface. As far as effort CA with a GP slot machine is much easier. However I prefer the action of the hinge point better. I'll use them again.
badger5964 is offline
