Chris, I thought exactly like you. The ethernet version seems to be the problem. The manual shows it can be attached to only RF RS-232 modems or OEM modems. The loopback connector was not supplied with these ethernet versions
I tried chacking all the settings for the channels as well. Did you work with 2 of the RS-232 modems? Thanks for your help.
