RE: cermark F-16 pulling hard right. Help!!!
i would check your elevator set up. sounds like your right stab is giving more input than your left. Make sure your linkage is the same length and you have your atv set up the same. run your elevators up and down slow to make sure that they track the same. If that is good, i would try doing it with the engine running to see if you are getting any glithches from the vibration.
ken
