Thread: servo bounce
Old 06-11-2007, 02:13 AM
pkoury
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: servo bounce
As posted check all your connections, the servo is not getting enough voltage. You ca also check by pushing on the control surface, it should be easy to move it cause the servo will not have enough holding power. The reason the servo "bounces" is because when returning to center it swings past center because its not strong enough to stop the motion. Every time it swings past center to a lesser degree until it has enough power to stop the motion. When you plug the servo straigh into the RX the problem will go away.
pkoury is offline
