RE: cermark F-16 pulling hard right. Help!!!
I had the same problem with the nose wheel needing a reverseing Y harness and used the lead with the adjustable center on the nose wheel to be able to center it later as needed. However later I changed the hitect Rudder servo for a futaba servo and low a behold I didn,t need the reverser any more All the other servos were Futaba. Maybe you mixed and matched servos like I did at first.
