Spinner for large apc
I need a 2.750-3" spinner to fit an 18/10 apc prop. The prop hub diamater is 1.750" and all the spinners I've seen only have a knurled contact area of about 1" diameter. There is a warning with the prop to be sure that the knurled area contacts the entire hub to alleviate stress. I don't mind slotting and balancing the cone if I have to, but I really don't want to lay down 75 bucks for a custom true-turn. Plastic cone with a aluminum back plate will be fine. What are you using???
